I know there has been loads said about this already but I'm still unsure?
If I were to use a 1.6 CVH that normally runs a single carb, would I have to change to a megajolt or could I use the existing ignition system? I've also got a 2.0 pinto EFI same question? Sorry for being thick. |
Generally, you need Megajolt, as most Sierra carbs are electronically controlled and have a huge multiplug on them. The factory ECU controls both the carb and ignition, so you need an aftermarket system if you want to separate these concerns. Same with injection.
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
| Thread Tools | |
| Display Modes | |
