Old 31st May 2015, 11:52 PM
Badger Badger is offline
Some nice tinwork there mate, that bead roller looks like the mutts wossnames!
If dysfunction is a function, then I must be some kind of genius.
Old 4th June 2015, 09:14 PM
SteveH1 SteveH1 is offline
Hi
Do you have plans for the bead roller or did you just wing it.
Thanks
Old 5th June 2015, 03:18 PM
Rosco Rosco is offline
Originally Posted by SteveH1 View Post
Hi
Thanks
yeah just winged it, it works well but theres a few things i would change it doing a mk2
Old 7th June 2015, 09:27 PM
Prop shaft turned up from dunning and fairbank on Friday so lots of jobs to be done
So got the prop bolted in and mounted my rear view mirror
Old 7th June 2015, 09:28 PM
Gear linkage mocked up
Mounts for bel crank
Plate for centre bearing sorted and mounts for gear lever done
Not overly happy about the handbrake lever position but it's not in the way when sat in the seat and it's the best position for the cable
Old 7th June 2015, 09:29 PM
Front cross brace done
Water pipe mounts, will have rubber grommets in
My dad cut me a bigger gear out of mdf on his cnc as a test, as the normal 140mm that people use was way to small, the motor needed to much grinding out
We went for 160mm and the motor only needed a little bit out in a few places, I'm really happy as the motor doesn't sit through the bottom of the car
I will get a steel gear laser cut out now, we powered it up on the mdf and it worked a treat
Also got the handbrake mounted
Old 7th June 2015, 09:30 PM
Old 9th June 2015, 09:43 PM
Got a couple of prop catchers done tonight, these two will be welded on, I'm going to make a front one that bolts on else I will never get the prop in and out
The tube was a bit of rear hub tube I had left over and it's a perfect fit in between the tunnel
My Build Thread
Old 22nd June 2015, 08:56 PM
Quick update, just tacking the last few bits onto the chassis, my vin number came today, just need to make a plate and sort some earth points then ready for powder coat
Passenger bulkhead bead rolled and fitted
Gear lever taking shape
The black smudge is where I'm going to weld my vin number
My Build Thread
