Old 21st October 2015, 03:59 PM
Originally Posted by norton View Post
Nearly all done. Annoyingly the last arm I thought I finished went wonky so I need to correct that. Also still waiting for the suspension brackets which should turn up any day now I hope.
I'm off next week which should give me the time to get it on its wheels and the engine, box and diff mounted too.
Doh! You have clearly tried the VTR325 with M16x1.5 bushes.
Old 21st October 2015, 04:54 PM
norton norton is offline
No I used m14x1.5 threaded drop links. I got them from eurocarparts. Thelatheman turned up the threaded bush for me.
Old 21st October 2015, 04:56 PM
Ahh I see. Thanks for that.
Old 22nd October 2015, 03:26 PM
So I need to organise myself better rather than attacking all the jobs in one go.
So firstly I'm gonna get the cooling system sorted. I'm trying to track down a Westfield owners club person who had some specific reroute hoses made for the top hose. SFS hoses made them but won't remake them without the original persons permission. They make for a far neater job and get the top hose tucked in nicely above the exhaust and by the cam cover.
I quickly hacked the bottom pump inlet about this morning. I've no access to a lathe though so I'm unsure how to machine a hose retaining recess onto it.
Old 22nd October 2015, 10:00 PM
Rosco Rosco is offline
You can post it to me if you like?
My Build Thread
Old 23rd October 2015, 12:29 PM
That's a kind offer but setting it up would a real ball ache. You'd need to remove the chuck, fit a face late, then an angle plate onto that then the piece to be worked into that which will then need centring.all that just to turn a shallow recess to help retain a hose in place.
I could file something adequate into it so its probable best to just do that.
Old 23rd October 2015, 01:23 PM
ok mate, can you post a pic, how about a bead of weld or and olive so to speak
My Build Thread
Old 23rd October 2015, 02:51 PM
I ll take a pic tonight when I'm home. Welding it could work. I have an idea re that which a picture will explain better than words.
Old 23rd October 2015, 03:07 PM
SteveH1 SteveH1 is offline
There was a thread on here and the fella split a copper brake line and pushed it on the opening round the edge then soldered it in place but i cant rember which thread
Old 23rd October 2015, 03:11 PM
If you mean the small steel L bend then no we're talking about the actual inlet which receives coolant from the radiator. We want it to point forwards not to the passenger side.
