Old 29th August 2013, 05:12 PM
GSF do a sleeve for VW AUDI that will clamp over the pipe and is neat.
2985911 is number,measure od of pipe
Old 29th August 2013, 08:05 PM
Hi David,
Most clamps for pipe are measured in diameter.
Normally they specify a range between two diameters for example 35-42mm clamping range.
Have you picked up your bodywork yet?
Old 29th August 2013, 09:14 PM
Originally Posted by Johno View Post
Hi David,
Not yet. I am hoping to get an email soon. I am off next Friday so will ry and collect it then.
I managed to sort out the clips last night and I have also bought some exhaust bends. I will try and fabricate that before I get the bodywork.
I'm also working on the interior panelling and trimming the carpet to size as I can see this being a right pain once the bodykit is in place.
Thanks
Old 7th September 2013, 10:01 PM
I've done a bit of trial fitting with my new body panels..
Here are some photos
Side panel
Back panel and scuttle
What the engine bay will look
Old 9th September 2013, 08:49 PM
Default Another photo
It almost starting to look like a car!!
Old 9th September 2013, 09:50 PM
Looking good! Mines still upside down. Any tips or advise for me?
Old 9th September 2013, 10:59 PM
I think I'm going to have to buy more clamps and will defo need more than one set of eyes when it comes to aligning ang riveting the panels.
I'm not 100 percent how to mount the rear panel. I was expecting the back edge to join against the metal bar that runs alongside the tank. There is a good 5" of clearance so I may just have o attach it at the sides or make up some brackets.
Old 9th September 2013, 11:10 PM
Yes I feel a little overwelmed by the task of making this all fit. With regard to the rear panel I'm just using the sides for support and hope that the rear wings help support the rear panel.
Old 9th September 2013, 11:15 PM
I may also put a bit of ally sheet underneath to stop it acting like an air brake. This may make it a bit stronger.
Did Alan tell you about his dash and aero screen designs?
