Old 20th May 2010, 06:42 PM
[quote=MightyMouth;38523]Handy,
Rather than a whole new thread, why not an announcement post pointing to the first post about the club?
/QUOTE]
MM......good idea, i take it you mean a link to the relevant post showing the discussions that were held at stoneleigh?
As Deezee has pointed out the info has been hidden within this thread, maybe its due to the popularity of the whole idea.
If so then thats a good solution to a highlighted problem,
Would you be kind enough to create that link please Mighty Mouth ?
Old 20th May 2010, 06:46 PM
Originally Posted by deezee View Post
Twin Turbo, yes your right, those additional features could be part of the website as a whole, but rather than trying to write a bespoke website to integrate those features as separate elements, I imagine it would be easier to use existing features on solid forum software. Another attack on the forums or club would be a disaster and I can see the requirement for some robust software.
There's no need for a Bespoke site, there's content engines out there that will do all you want and more
Old 20th May 2010, 08:07 PM
Yes, I am planning on using Joomla with a custom template.
No Problem
Old 20th May 2010, 08:17 PM
Originally Posted by MightyMouth View Post
No Problem
Thanks MM, just seen the link,
Old 20th May 2010, 08:20 PM
gingea1pom's Avatar
Keith,
How did you make it go straight to the post and not the start of the thread?
I started to think I was getting good at creating links, that put me back in my box.
Build Pictures
Old 20th May 2010, 09:46 PM
Originally Posted by gingea1pom View Post
Keith,
Haha, there are several ways but the easiest is to look in the upper right corner of the post and find the number, in this case it shows #125. That number is a link to the post but if you use that link it will only show that post and not the rest of the thread, the trick is to alter that URL.
If you look at the URL for the post it is "http://www.haynes.co.uk/forums/showpost.php?p=37541&postcount=125"
The bit after the PHP? is the important bit. p=37541 is the global forum post number and the &postcount=125 is the thread post number which adds the number in the upper right corner. This makes it link only to that post without the rest of the thread.
If you replace the &postcount=125 with &post=37541 so the link looks like "http://www.haynes.co.uk/forums/showpost.php?p=37541&post=37541" that will make it go to the the post within the thread.
If you leave off the &post=37541 so the link looks like "http://www.haynes.co.uk/forums/showpost.php?p=37541" it will do the same as if you leave the &postcount=125 except it won't show the post number in the upper right corner.
Does that make any sense at all?
Edit:
Actually I just noticed the real easiest way is to click the number in the upper right then on the page that opens copy the link above that number that says Thread: such and such
Old 20th May 2010, 09:50 PM
hover over the post number on the right of the post
Old 21st May 2010, 10:30 AM
No MM......
We can build cars but we cant do everything.....
Old 24th May 2010, 05:51 PM
Default Club Gazebo
It might be a bot early to start thinking about but there is a Gazebo on sale at Aldi this week
