Old 4th October 2012, 10:37 PM
mgglep's Avatar
mgglep mgglep is offline
I did exactly the same thing I used 3 mm Ali for floor and tank I used 3/16 rivets and sika I used countersunk rivets on the edge where the side panels go I am hoping the panels will go over
My Build pics
Old 5th October 2012, 01:58 PM
Queer thing is Andy my current Ebay feedback is 999 ....me thinks something devilish is going on
mg you should be ok as long all the dimensions are correct but it will be close, which is what you want anyway
Old 6th October 2012, 12:27 AM
Started on pipework today and got some p clipped inside the trans tunnel
the ally I'm using to mount p clips to is a corner strengthener that plasterers use
I cut along the apex to give me two flat bits.
I purposely left the nearside floor off to make fitting the pipes easier
Old 6th October 2012, 08:46 PM
Oscar Oscar is offline
This is what I love about this forum, the ingenuity!
Will have to have a word with my cousin (a master plasterer) about getting some of that, the greatest form of flattery is imitation!
Photos of the project so far:
Old 7th October 2012, 01:47 AM
good progress today....have just about completed the petrol and brake pipe mounting throughout the trans tunnel, got a bit busy on that side so decided to mount the loom clips on the other side....will be getting the other floor on later today
I did manage to do the trans tunnel with just 10 fixings
from the engine bay
complicated bending near the diff mount
one of Sylvains flexy lines was easy to hop over the fuel feed/return
Old 7th October 2012, 08:27 AM
I reckon Chapman would have been proud of that one Kev
Old 7th October 2012, 09:40 AM
Very neat installation Kev, it is brilliant (and looks good )
Just a question: why the central brake line has to cross the fuel lines? Why haven't you routed the fuel lines all the way on top of the brake line, which would have been routed all the way on the lowest part of your ally strip? It would also have allowed a larger curve-radius on the bend of the brake line to turn around CP14 and connect to the tee-piece.
But I'm sure there is a reason
Old 7th October 2012, 10:37 AM
Liking the progress Kev
Old 7th October 2012, 04:37 PM
Mmmm....might try to swap those around Sylvain or at least top one for bottom one.....got the diff area all p clipped off
rob....I will list everything that I have used as a part off at the end of my build and the list will be quite comprehensive
plastic clips pop riveted on to hold loom in place
Old 9th October 2012, 11:26 AM
I have had a little rethink regarding my pipework down the trans tunnel.....not having the diff or handbrake cable mounted meant my guesswork regarding them was way out, so I have reworked them to clear the above items, one pipe I had to feed through the diff bracket which worked out quite well and I have moved the brake pipe down to the bottom to stop from crossing over as Sylvain pointed out, so here are the new trans tunnel pipework photo's
From the engine bay
to the tank (feed & return) with homemade olives soldered on
getting around the diff with out fouling
another angle
