Old 7th September 2015, 10:55 PM
Ianr Ianr is offline
From what I've heard on other forums you are the one supplying the information about the engines peak power so if you want 8k then that's what it is!
My peak power on my MX5 engine is going to be 3000 rpm - er - no I don't think I'll get away with that - so as long as it half sensible .........
Old 8th September 2015, 09:47 AM
Rosco Rosco is offline
Originally Posted by norton View Post
If needed, could the bonnet not form the top cover/half/something of the air box?
yeah i thought that but i would like to let a good bit of cold air in, im thinking foam filter sticking through a hole in the bonnet, then ive not got to mess around with a scoop or anything, just cut a neat hole in the bonnet
yeah that sounds good, I'm going to get it mapped so will see where it gives peak power
My Build Thread
Old 14th September 2015, 07:58 PM
Not many photos tonight but it doesn't mean I've not been busy, got my driveshafts from j&r on eBay greased, built up and fitted
Got a type 054 battery, think it's going in the passenger footwell behind a foot rest, so made the foot rest fit and made a strap out of stainless
This will bolt through the floor from underneath, all bits need a bit of padding here and there
Then spent most of Sunday drawing and deciding how to do my air filter
First try was with a k&n filter but looks to big,
My Build Thread
Old 14th September 2015, 08:00 PM
Next is to suit an itg sausage filter over the top, this is what I'm going to do, I've got to make a new fuel rail and a base plate
Std injectors which will fit in the new rail/bracket
This method seems the simplest, easy to make, most compact and uses an off the shelf air filter
My Build Thread
Old 16th September 2015, 08:52 PM
Well got all my anodizing back today, looks sweet
Gear shifter
Roll cage bungs, I admit I got carried away with these, but I do love it! Made a bit of a logo with my initials
My Build Thread
Old 16th September 2015, 08:54 PM
Brake tags bonded and riveted on (I spoke to the tech iva man at the dvla about this and he said it's fine as long as there secure) also got all my brake pipes back on tonight, I just need to rivet the p clips on
Rad brackets fixed on and fan fitted
Brake res fitted
My Build Thread
Old 16th September 2015, 08:57 PM
My air trumpets turned up yesterday so now I have 4 short ones
Started the fuel rail bracket
Back plate drawn up
Just need to order one of these filters
My Build Thread
Old 17th September 2015, 08:53 PM
Well finished my fuel rail bracket off tonight, just got to make a few bosses for it
Then onto the handbrake cables, I thought this would be an easy job but it wasn't, the cables weren't really long enough and not sitting nicely, I was ready to leave it for tonight then I thought about making some exstention tubes
The cables are a snug fit in the tubes and locate on 50mm also it stops them from rubbing on the diff
[url=http://s133.photobucket.com/user/corsaboss/media/September%202015/B44B1114-E9A5-4D6E-9CB4-B761C1846667.jpg.html]
My Build Thread
Old 17th September 2015, 08:54 PM
I just need to make a couple of brackets to hold the cables in place off the wishbone bolts
I've removed the adjuster from the cable but I will still have adjustment on the cable end fitting as it has grub screws in
My Build Thread
Old 18th September 2015, 10:21 AM
Don't be tempted to have a "few" notch handbrake as you don't get leverage to give you good brake force,4-5 notches is good .
Nice build .
