Old 14th May 2014, 10:30 PM
Default Misfire
Is anyone an expert with mx5 engine.
My car idles fine but as soon as I touch the throttle the engine revs drop. This is the point where the throttle position sensor switches in. (I got my multimeter out to check). The engine misfires throughout the rev range and seems to be getting worse.
I have changed the coil and the ht leads.
The engine seems to be running rich as my plugs have black deposits on them and I've got the same in the exhaust. (Powdery deposits so not oil)
Has anyone got any ideas. I have checked everything I can think of apart from the temp sensor for the ecu which I will do next. I have also tried unplugging the lambda sensor but this didn't make any difference.
