Old 13th March 2009, 06:01 PM
If you need to tow anything again Mightymouth,the largest number on the chassis plate is the max vehicle weight with trailer etc or GTW to give it the proper title,Gross Train Weight. All this means is the weight of the car and what you are towing add up to GTW,other two numbers are axle weights and add up to max design weight of car.
Cheers.
