Old 26th May 2009, 02:53 PM
axle's Avatar
axle axle is offline
Wink Mot/iva
Hi Guys
Reading on the forum, can not make sense what is first as some one else some where else on the forum was talking about setting the brake limiter on the rolling road of the local MOT station prior to IVA! So what is first MOT or IVA? Surely the car has to have all its normal documentation before the MOT!
Cheers Axle
Old 26th May 2009, 03:26 PM
fabbyglass
You can MOT on a chassis number
Old 26th May 2009, 03:33 PM
As far as I know, you only need to have the IVA test to register & tax the car.
I believe that most local MOT stations will let you have the use of their rolling road to help you to set up your brakes prior to the IVA
The costs should not be too great, i guess it will depend on how well you know your local testing station.
You may need to provide some general axle weights to allow the rolling road operator to calculate the correct brake effort & balance.
This way, at least you know your brakes will be OK for the IVA test.
Old 26th May 2009, 03:46 PM
axle's Avatar
Unhappy
Hi Guys
Does this mean you can trailer the car to the MOT station and after passing it can be driven for the IVA, or Have got the wrong picture here?
Old 26th May 2009, 04:10 PM
I may be completely barking up the wrong tree but this is my understanding of the way things work.
The car is taken for an IVA test.
Once passed you are issued with a MAC certificate.
The MAC will enable you to register & tax your car.
An MOT certificate is not required for the first 3 years as per new car.
I also believe that if you are able to find an insurer that will insure the car on the VIN number the car can be driven to the IVA test.
Now I will duck for cover
Old 26th May 2009, 04:26 PM
axle's Avatar
Thumbs up
Cheers Ronnie
You have made my day!
Regards Axle
Old 26th May 2009, 05:14 PM
I could be wrong but have wide shoulders to bear the grief.
Mot on chassis number self stamped (right side of chassis) can be driven to test if pre booked (nearest station )Trade plates would save grief from plod.I have tested many imports this way and it gets them on the VOSA system as they have no uk reg.
IVA
DVLA with cert from VOSA and register and tax.
I think it has been mentioned that you do not need a test for three years after.
FrankieBoy or Spud69 can probably shed more light on this.
