Old 14th September 2009, 07:21 PM
squbti's Avatar
squbti squbti is offline
Default Head lamps
hi all, does anyone know how far apart the head lamps should be or how long the pipes for the head lamp holders are?
Samy
Old 14th September 2009, 07:32 PM
my headlamp brackets are 12cm from the chassis rail to the center of the hole in the bracket, this then makes the holes between the 2 brackets 90cm wide, tho it depends where on the chassis you weld the brackets, mine are welded above the upper shock mounting bracket.
hope that helps.
Old 14th September 2009, 07:47 PM
squbti's Avatar
hey andy , thanks for the reply its exactly what i needed to know, i will have them in place tomorrow & they will be in the same place as yours are so this has realy helped.
thanks
Samy
Old 14th September 2009, 07:57 PM
no prob, glad to help,
a little tip..... don,t forget to angle the end of the headlamp bracket tube that you weld to the chassis rail, other wise your headlights with look cross eyed
Old 14th September 2009, 08:36 PM
squbti's Avatar
lol, now that would not look good.
Old 14th September 2009, 11:07 PM
7 degrees i believe.
now thats sad is i havent seen the book for about a month lol.
dont forget to use andys measurements as a guide. if you fit different size headlights to what andy is fitting you may run into problems
