Old 6th April 2010, 09:29 PM
Question Zetec Clutch release bearing !!
My new clutch arrived this morning.
The cover is a perfect fit to the Zetec flywheel & friction plate a direct fit to the Type 9 gearbox spline.
Thanks for that tip Cozzer
Here's my problem ..... The release bearing that my local motor factor got in for me is exactly the same as the old sierra one.
It is supposed to be the CT133 bearing .... Took them 2 weeks to get it & cost £23 .... Non returnable as it was a special order
I make this post in the hope that somone will know the difference between the two bearings .... I assume the CT133 is thicker than the Sierra one in order to give a longer throw !!??
I have searched every where .... Where can I buy the correct bearing ?
Another thought .... Has anyone tried to raise the clutch fork pivot pin in order to gain a bit more throw ?
Ohhhh I had best say 1.8 Zetec to type 9 gearbox
