#21
Feelin like a teat tho over the driveshafts
They say obsession will mess with my brain..... But I love the feeling of going insane.... Roadster No 2 build Cost to Date : £93 ** New Blog @ http://carlsroadster2.blogspot.com ** |
#22
Sorry my efforts have not been of any use to you .... Hope you manage to get it sorted.
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk |
#23
Know that feeling thanks for your efforts dude
#24
Sorted now?
#25
i'll let you know
still if you fancy a day of coffee and biscuits mark your walcome to come help with the rest of the rear brake lines ;~)
#26
Abs ring doesn't seem to be removable
#27
Hi, mine all went together fine without removing abs rings or anything else.
makesure the hub is pulled all the way through the bearings you should see a couple of threads sticking through the nut. also make sure the shafts havent popped out of the joints and check the prop flange on the diff is central in the tunnel. finally when its all together you should be able to move the shafts a little sideways this will show nothings binding hope this helps Ray ![]() |
#28
No need to take that off if it's possible to anyway.
| Thread Tools | |
| Display Modes | |
