Old 26th February 2011, 06:20 PM
brainbug007's Avatar
Default Removing the engine
I started to strip my donor (CFi CVH) today with the aid of a haynes sierra owner's workshop manual and thought it best to try and get the engine and gearbox out 1st. I managed to get as far as removing the air and draining the coolant but then started to struggle a bit as I don't know much and trying to learn as i go and what a lot of the parts should look like when the book says remove x from y. Especially with all the hoses that connect into everything! Should I just try and disconnect everything attached to the engine and worry about what they are later when I try to get the engine into the roadster? Or just slowly work through each bit as I get stuck and follow the order the book says? Any suggestions would be appreciated to help out a newbie, stuck at the moment on trying to work out what hose/s are the brake servo that connect to the inlet manifold? (not really sure what the inlet manifold looks like either..)
