Old 9th November 2012, 11:36 PM
Teeth are ok Bob but I had a helluva tash.....Magnum PI would have be jealous as hell...should have been wearing a mask.
with the sump off I made a few measurements and off came the bottom and I hope to weld it back up tomorrow with a added collar to retrieve some capacity
here is the first cut on the sump
here are the parts to make up the collar to retrieve capacity
Old 10th November 2012, 04:58 PM
If there`s no starter in the way Kev a winged sump is a good way of grabbing some capacity back
http://static.summitracing.com/globa...m-121002_w.jpg
Old 10th November 2012, 05:23 PM
no problem there Bob, that part of the sump is unusually at the front of the engine
Old 11th November 2012, 06:04 PM
A man with a grinder kev
http://www.nsra.org.uk/newforum/showthread.php?t=44641
Old 11th November 2012, 06:08 PM
Nearly got my sump finished will have a fair bit o flapwheeling to do and then a coat of paint
Old 11th November 2012, 07:53 PM
Originally Posted by robo View Post
hey hey... a gadgy after my own heart ,,,,,gladly... I am not THAT obsessive
Old 12th November 2012, 09:28 PM
got my sump finished ....just needs a clean and prep for painting....decided to move my drain plug to one of the wing sectors as I intend to fit a quickvalve to make changing the oil easier also put a new baffle in to make sure there is oil at the pick up under hard acceleration
Old 12th November 2012, 09:49 PM
Did you check it for pinholes? I recommend water inside and chalk on the seams.
Old 13th November 2012, 09:43 AM
checked for pinholes and cracks using acetone.....if there was any it will find them due to its ability to creep past/through anything.....I found 3 which were duly re welded, any I find once on the car I will probably use JB weld.
Old 15th November 2012, 10:14 AM
That must have put back what you nicked of the bottom of the sump + a bit I would have thought Kev. Just need a bit of 10mm thick plate under that now for a skid plate
ob
