Old 18th December 2015, 12:39 PM
Knowledge and too much info .....
Old 19th December 2015, 11:37 PM
Originally Posted by K4KEV View Post
Rosco ...you might want to re engineer the front mudguard stays as the book ones are pretty useless, they crack and shake like a woman's mechanical friend
Lol.
I used kev's design and they are spot on. Although 1 does wobble ever so slightly at 70mph. I also used 5x40mm plate which is probably overkill but it's what I had.
Old 20th December 2015, 12:58 PM
Originally Posted by SeriesLandy View Post
Lol.
I think the book's design for the wing stays is not that bad if you replace the 3mm strips by 5mm. Mines are now book's design (a bit different on WS1, and around the brake line though) with 20x2mm round tubes, 20x5mm strips, and 5mm plates, and they are very stiff, no wobbling at all whatsoever, at all speeds. I'm very pleased with them.
If I have had the facility to nicely bend the tubes as Rosco did, I would have gone this route too, because assembling the tubes together on WS1 with the right angles, etc., is a part I found very difficult to achieve. IMO, making the tubular part of the wing stay in one-piece is a very good idea.
If the steel strips holding the wings are 5mm thick, Rosco's wing stays should not wobble at all. Just my humble opinion though
Old 20th December 2015, 02:27 PM
MrFozzieBear MrFozzieBear is offline
If you've done the same as me and got the MK wing stays.
They will be spot on with very little vibration when you've got it on the road.
I put them on dry first because they needed slight fettling on the bottom bracket. But they are solid and look good when powdercoated.
Old 20th December 2015, 07:33 PM
Rosco Rosco is offline
Cheers guys, yeah I gave in and brought mk's, sound like they should be ok then, I couldn't face making anything else lol
My Build Thread
Old 20th December 2015, 07:43 PM
norton norton is offline
Are you using mx5 or Sierra uprights?
Old 20th December 2015, 07:48 PM
Sierra
My Build Thread
Old 20th December 2015, 07:58 PM
Ah, I've been looking for an off the shelf mx5 stay
Old 20th December 2015, 08:01 PM
Westfield sell these for 35 powder coated and they are solid
Old 20th December 2015, 08:09 PM
Ahhhh, I've been searching but not found them. Do you have a link?
