Old 14th February 2013, 08:37 AM
Couple of things kev, First on is the ratio of master boresize vs slave boresize. The last car i converted to hydraulic clutch was a total brain ache, I had about 6 inches of pedal travel (if i wanted to keep the pedals all at the same height at rest) and struggled to find the correct ratio of pedal movement vs clutch arm movement while maintaining a clutch that was not to heavy or to light . Or one that was so light it never released the clutch and one that was to heavy to be practical for driving. Got there in the end but not after going through a dozen different combos of bore sizes. Next thing is to check that the torque movement of the lump under load wont get that slave rubbing and buzzing on the chassis. Looks like you could get a rizla trapped in there
Just thoughts
Edit. dont trust that plastic waste pipe kev the stuff age hardens and splits.
Old 14th February 2013, 08:20 PM
There is no stopping the Man !
Old 23rd February 2013, 08:51 PM
Me thinks I will cross that bridge when I get to it Bob but thanks for the heads up on it....my other headache is now solved, the turbo elbow had a wedge cut out of it and I had a bash at tigging stainless steel, I found it similar to ally except for the size of the arc which can be tiny. So now I am looking at welding on a 90 degree bend to bring it out of the side panel close to the bottom.
Here is my re-fabbed turbo elbow and first time tigging with stainless
Old 25th February 2013, 08:53 PM
Exhaust is now coming together and I have learnt a lot about tigging stainless, and it aint as easy as I first thought.....got my 90 degree bend on and will soon fit and weld on a 3 hole flange to fit the outer exhaust pipe and silencer.....one picture is of me just offering the outer pipe up to check any clearance issues and none so far.
cut and welded up
looking from inside the car
these two lower bolt are t*ats to get at but do-able
and what it should look like
Old 1st March 2013, 01:19 PM
Should see me finished the exhaust today.....after reading about one of Jason's failure points, I decided I was going to incorporate a decibel killer into my exhaust while I could, so I got a piece of old exhaust tube blanked off one end , then cut some slits along the pipe and then dinted the tube in on one side of the slit meaning the exhaust would momentarily have to travel backwards before going forwards again which should give a small amount of noise canceling
As you can see from the pictures it is going in before the silencer which will help even more because most decibel killers just go inside the silencer, this will be removed post IVA as I want a straight through exhaust on final tuning, the last thing I will have to do will be a rolled exhaust tip.....will be making that as well
piccies as usual
Old 1st March 2013, 05:31 PM
Nice one as usual Kev,not a criticism but something that would bug me,the sharp angle of the exhaust exit may be liable to a lot gas cutting due to high temperature gas straight from the turbo hitting the pipe.
You will understand what I am getting at,a liner at that point may be a long term solution.
Old 1st March 2013, 05:42 PM
will_08 will_08 is offline
Jesus Kev
You don't half plod on with your build pal, how do you fit it in?
Old 2nd March 2013, 09:32 AM
yep Paul ....it is a case of suck it and see, wont be of a real concern until after IVA when it gets some welly then I might consider re-shaping the passenger footwell incorporating its own built in permanantly on footwarmer
Hi Will.....steady away mate steady away, although you will see some rapid progress over the coming months as I want it on the road this year
Old 2nd March 2013, 09:16 PM
After much trolling the internet and ebay last week for a tight radius rolled tip stainless exhaust end and not finding anything remotely suitable, I do what I usually do and make my own....now in doing that it means I can be different as usual. So here is a quick run down of how I made it.
First raid the scrap bin for a piece of 2" stainless exhaust pipe, then give the bit I'm using a polish up and scrape the carbon out from inside, then I give the piece a 45 degree cut then mark out the next angled cut to intersect the first one, now grabbed the first offcut and gave it a bash or two to flatten the steel, now using the 45 degree angle as a template mark out on the flat piece of steel. Now attack with angry grinder until correct shape, when that has I nice fit its back onto the tig table and weld it onto the exhaust tip grind back then polish up with a powerfile ......now to achieve the "rolled tip" I silver soldered a length of shaped brake pipe onto the exhaust exit, the following pictures will make sense of what I have just described.
Old 2nd March 2013, 09:17 PM
