Old 20th May 2013, 09:22 AM
Best of luck again!
Old 20th May 2013, 09:36 AM
Good luck spike, hope it all goes well
Old 20th May 2013, 11:01 AM
+1 good like spike.
Old 20th May 2013, 12:29 PM
Dualist's Avatar
Dualist Dualist is offline
Good luck dude
Old 20th May 2013, 07:17 PM
Thanks for the support guys, well this is how it went. I passed everything on the list from the initial inspection with no problems, however the inspector noticed a small amount of brake fluid on the back of the brake master cylinder after the tests. On closer inspection it appears to be a faulty seal with the piston seals. This is 100% my fault for using a second hand component from Ebay! The most annoying thing is it passed all the roller brake tests.
So basically, I failed!
A new master cylinder and a couple of hours work to sort it.
Old 20th May 2013, 07:38 PM
Does that require a full re test spike or is it just to check the brakes?
Old 20th May 2013, 08:11 PM
Just an MOT Style brake test and a quick drive around the car park he said. Not to bad really, its just a bit annoying having to get the trailer again.
Old 20th May 2013, 08:52 PM
bugga....
Almost there.
Old 21st May 2013, 08:33 AM
jason jason is offline
Bad luck Spike.
At least it is an easy thing to put right and hopefully they will fit you in quickly for a re-test.
Old 21st May 2013, 09:13 PM
insure it and drive there :-)
