Old 13th August 2013, 11:44 AM
Originally Posted by TheArf View Post
Like you Phil I will only bite my tongue so long, I am sorry for the pressure you are under in your personal life and your business, but that does not give you the right to rubbish other peoples efforts, maybe not everyones welding is top notch, but they do have a go.
I wonder how you would fare if you were to try the jobs that some of the others on here have, I am qualified to make comment on their work but wont as I know the effort that these guys put in and good for them, each time they do something on their build they are learning something new OK
my rant in now over
Thanks for saying that Arfon, I was just about to go out to the garage and cut up my chassis, that I've spent 2 years putting together, and wishbones up for scrap as apparently there's nothing good about them. I think all too often people forget, most of us are putting a together a car in an 8x18 ft garage with the tools we have available and can afford with our own less than perfect amateur skills. But that's ok, these cars may not be perfect but it's about building a car and challenging yourself and not so much about the end product as good or bad that may be.
I wanted something to keep my mind busy and that wouldn't cost a fortune as times are hard. I also wanted my two young children to see what was possible so they don't grow up thinking what they want to do is out of reach or not possible like I did. But lets not get too deep about this.
Basically Phil you've just demotivated every MX5 Saturn design builder on here!
Nice one!
Seriously thinking of not using this forum anymore it's too depressing!
Old 13th August 2013, 12:23 PM
I think you have missed the point some what, go back and read my post again and try and pick out the concerns over the designs from a safety point of view rather than it being a personal attack on your self.
Old 13th August 2013, 01:34 PM
I didn't think it was a personnel attack on myself. I understand your concerns, but it doesn't do anybody with a finished chassis/car much good though does it. Unless they decide not to drive it. Or do it all again differently.
Old 13th August 2013, 01:36 PM
And you aint qualified enough to criticize me Phil, believe me you aint.
Old 13th August 2013, 01:39 PM
CTWV50 you have a p.m. mate
Old 13th August 2013, 06:37 PM
PorkChop PorkChop is offline
Originally Posted by TSM Locost View Post
Thanks for that Mike; saved me the effort To save pople flicking through, Keith Tanner's nose mount design is very similar to Phil's design.
On another note, I think people are being too sensitive here. I didn't see Phil criticise any one person. Bear in mind, I've got a SSC based MX5 chassis (well, I have 2) and I've actively contributed to discussions with other builders both on this forum and IRL on different aspects of improving the design. I don't feel offended.
Phil does have a point though about welding quality. If your welding isn't up to scratch (which is a very real possibility with a home build, not saying anyone in particular is not up to it), then should you really be building a car capable of going over 100mph?
I think he's also spot on with the diff mounting designs. It is incredibly frustrating to have the same topics come up again and again with carbon copy proposals and outcomes (not that I'm blaming you Short in the slightest, you are contributing with an alternative design). Plus, like I said, the Americans have already examined this in detail. It seems counterproductive to not use their findings as our basis and tweak the designs to suit the Roadster.
Phil has also highlighted the one thing about the SSC design I believe could be bettered; the threaded adjusters. At one level, I would look at using a different thread pitch on the wishbones so that a standard rose joint can be used.
An alternative could be to use the adjustable wishbones to set up the car, then make a second set of fixed (or semi fixed) wishbones to those settings. This is what Formula Student builders are advised to do rather than have rod ends acting as outboard ball joints, which usually fail. Although, I would point out I saw a Northern saloon car championship RS200 (replica I assume) at Stoneleigh this year with a very similar threaded adjuster design to that laid out by SSC and the book.
Another option might be to see if an adjustable system similar to OEM Mazda, or shims, could be implemented with fixed wishbones.
WRT the rear upper wishbones, I think it will be difficult to find a way around this without redesigning the outboard end of the wishbone a la Johno's latest design. I do think that it should be possible to have an acceptable set up for the rear suspension using the SSC design.
Old 13th August 2013, 07:18 PM
If Phil post was constructive about the possible failures of the Saturn chassis then that would be fine or peoples welding but it doesn't come across like that at all to me. Apparently he can't sleep at night thinking about it's short comings! A bit dramatic. No?
We all know this and it's a good point so do destructive tests on your welds and make sure they're not going to let you down. That's what I did. There's no need to describe possible builders as "a less then proficient person" which is very polite insult to my mind considering the tone of his post.
Thank you, this is useful information and something I hadn't thought of.
I don't see this as much of an issue and like you think it's a workable design.
With regard to the diff support design, I see this as one of the fun/interesting bit's of the build, something we can all throw ideas around with. I enjoy the discussion. I'd like to avoid solid mounting if I can but if that's what it takes then so be it.
With regards to how solid a rubber mounting needs to be, I can jack the rear of my car up using the nose of the diff (obviously only a part built car at the time)
and it does not move at all in relation to the car chassis but that might change during a hard 1st gear launch, maybe 2nd gear launches could avoid this issue completely which might not be as daft as it sounds considering the weight of the vehicle.
Old 13th August 2013, 07:33 PM
I read the not being able to sleep bit as either tongue in cheek, or he's like me. I sometimes go over what I need to do with this bit or that bit of the build.
I remember Albert posting up a youtube vid of someone showing you how to weld, where it was more like how NOT to weld. People may not be as thorough as you are with weld testing etc. And Phil did say 'may' not 'is'.
Old 13th August 2013, 07:59 PM
I have been waiting to get that of my chest for the past 2 -3 years and I will never have any thing to say about the Saturn design ever again. But I will say this to all those that I have had conversations with about it .... see 'I told you so'!
Once again, hugely constructive, thanks Phil!
Old 13th August 2013, 08:17 PM
So I will make this my last input on this subject (well at least for tonight as the cider monster is taking hold) but Phil have you ever completed the build of a haynes because I have never seen anything posted with a completed car built by your good self if you have I appologise if not don't slagg off other peoples efforts and designs
Good night
