Old 17th January 2014, 03:05 PM
Makes sense now Sylvain,what a PITA to have to strip it down and start again.
I understand very well the weather causing you problems,I spent some time in northern Finland in the winter,3 hours drive north of the Arctic Circle not far from Mumansk.
Old 17th January 2014, 03:45 PM
Ha yes, where when the police makes an investigation, they ask you "What have you done during the night between the 25th of November and the 16th of March?"
Here, it is southern Sweden, so it is still OK, 7 hours of day time at the worst... but yes, weather is harsh for the Southern French I am!
Old 17th January 2014, 08:13 PM
I drove Le Camion in europe for a few years,why on earth go to Sweden from France del Sur ?
Old 18th January 2014, 01:09 PM
davidimurray's Avatar
I'm using a Stant pressure cap which is 20-25lbs. It does not sound to me like a pressure a radiator can't take, but perhaps the problem come from there too.
I thought that 14psi was about normal? 14psi gives a boiling point of 119c whearas 20psi gives a boiling temp of 125c
Old 18th January 2014, 03:32 PM
I can imagine a very good reason--------------its blonde and sexy
Old 18th January 2014, 04:26 PM
I see your point
Plenty of talent in France !
Old 19th January 2014, 09:32 AM
Yes, Adrian is right! I wake up every morning of my life next to the reason I'm now living in Sweden, and I'm the happiest of men
But we don't plan to stay in Sweden forever, and might move back to France or another warmer country within one or two years. And if I can get the Roadster registered there, it will be so good to drive it in the southern France weather!
Well, I drove 600km in the day yesterday, and came back with a pair of nice Cobra seats. Unfortunately, we could not take the DOHC out of his Sierra, so no engine so far... I think I'm going to buy the one I saw at the scrap yard, but will do that only after the inspection, next month.
Yes, I have been stupid enough to use one of these high pressure radiator caps we use on racing cars. It was the only one available when I ordered my parts from France last year, and I should have waited. The purpose of these high pressure caps is too keep the cooling system under a higher pressure, because the higher the pressure is, the better the calories exchange is. But the whole circuit has to be planed for this pressure, and it was certainly too high for my system/engine/radiator. Perhaps the head gasket broke just because of this actually, and I think you should have a reinforced head gasket when you use this kind of high pressure radiator caps.
So, I will definitely go back to a lower pressure cap, same pressure as the one originally used with the Sierra DOHC.
Thanks.
Old 19th January 2014, 09:21 PM
You have just been unlucky Sylvain,colling system will stand much more pressure than the cap say's or they would be bursting more regular if they got slightly over the rating of the cap.
I have noticed cap pressure's have risen and a lot of cars do have high pressure systems and as you rightly say the heat transfer is better and the boil point raised.I suspect its all to do with emissions and better combustion.
Old 30th January 2014, 12:30 PM
snapper snapper is offline
Would suggest head gasket
When white smoke stops water level has dropped below gasket level
Eventually all water would go as it turned to steam
