Old 9th July 2017, 07:36 PM
norton norton is offline
And no, I couldn't get any larger pictures...
Old 9th July 2017, 09:46 PM
garyout garyout is offline
She's looking mighty fine mate.. soon be wiring time
Gary
Old 10th July 2017, 09:35 AM
Shhhhh, I'm trying to forget that!
Old 10th July 2017, 01:35 PM
dean211277's Avatar
Looks really nice and neat. Loving the white and black combo.
Old 11th July 2017, 12:57 AM
Thank you, it's really come along in the past month. I should have the dash done and fitted by the end of the week. I'm unsure as to whether I should add some sort of structure behind. I certainly need to add something to fit the ecu and fuse/relay/witchcraft on to.
Should I also add a 'floor' to the underside of the dash/scuttle?
Old 11th July 2017, 06:36 AM
SteveH1 SteveH1 is offline
I was just gonna mount the hardware on the inside of the scuttle thats on the engine side.
Old 11th July 2017, 10:49 AM
I see a lot of people doing that and it makes perfect sense but I don't like the idea of a big empty void or the underside of the scuttle above your knees being open. I need to come up with something that makes it feel more finished.
Old 11th July 2017, 10:41 PM
Mainly for Iva, I put a panel at the bottom of the dash. If you can't touch it, it can't fail. I removed the drivers side after Iva as I needed a little more leg room but left the passengers and added a cigarette and USB socket for satnav and phone.
Old 13th July 2017, 03:16 PM
Eternal Eternal is offline
seeing as photobucket has gone crazy. Could you show me how you fitted your side panels? I cant decide if i should glue them or rivet. Thanks!
Skyline Roadster
Old 13th July 2017, 04:13 PM
I used both, glued along all contact points with maybe 15/20 rivets per side holding them on tight.
