Old 28th June 2014, 10:30 PM
It is but it was made into a trailer a yonk ago. New trailers are supposed to be IVAed now.
Old 29th June 2014, 08:24 PM
Some of you may remember me promoting wearing eye protection when grinding when I posted a pic my eye ball with a metal shard in it. Well I was wearing eye protection this time when the 0.8mm blade shattered,
like a hammer to the face.
I converted an old welding mask after that.
Old 29th June 2014, 10:33 PM
thailoz thailoz is offline
ouch !!!! glad you are ok .we do tend to take H&S a bit lightly when working on our projects but that shows you how easly it can bite you back.
full face sheild looks to be on the cards for me
Old 30th June 2014, 09:35 AM
Typical, I'll forget that idea then.
Old 30th June 2014, 08:45 PM
StruveD's Avatar
StruveD StruveD is offline
I would like to further add to the safety list, that if you are using a hole saw to cut through sheet steel, and said sheet steel is a crotch level... be sure to properly secure the steel from spinning. Sliced through shorts, underpants, thigh skin, and received a firm knock to the plums. After seeing my leg I wasn't sure what I was going to find in the gentleman's region.
Old 30th June 2014, 09:09 PM
Ahmen to that,had an 8in disc blow up on me once, luckily had full face mask hat and gloves on but still made me nearly incontinent.
Be carefull out there.
Old 30th June 2014, 09:21 PM
Well at least it wasnt in vain.
Old 1st July 2014, 05:22 PM
We all get a bit complacent with grinders. A friend of mine was wearing goggles and overalls while grinding when a blade gave up and it tore the top off his knuckle. Leather gloves are also a must.
Old 1st July 2014, 07:44 PM
We never listen though, even to ourselves.
On the trailer, I just weighed trailer with car all strapped down and it comes in at 902kg including the ramps and has 82kg on the nose as loaded. Well happy.
Old 8th July 2014, 12:30 PM
Well I'm just back from the IVA and...... I have a small list of things to do.
There were a few nuts that I had forgotten to re-tighten by the end like the adjusters on the caliper end of the handbrakes but the main fail points were
Radius on the front and side repeaters.
Radius on the top of the front shocks
headrest height in its lowest position is too low.
Air filter needs securing.
Everything else they liked. Retest on 23rd. Not a bad one really, a weekend of work.
