#431
#432
#433
#434
#435
#436
#437
2nd to none cracking build .
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
#438
#439
Bit more of an update,
Lifted my ride height up a bit, 5" front 6" rear, got all my camber and toe adjusted Then checked the bump steer, to start with from ride height it full bump it was toeing in 4mm a side After sliding the rack up a bit on the slots I've now got 0mm total toe at full droop 2mm total toe at ride height 2mm total toes at full bump Which according to my mate who lent me the lasers should be ok ![]() Just need to put the springs back on the shocks, and get the ride height correct and then corner weight it when it's finished and double check the alignment Next up, I've filled my iva forms out and sent them off! Woo hoo ![]() ![]() I have been on with other bits and bobs but still got a bit to do, I need to get cracking! |
#440
Jealous.
Has it moved under its own steam yet? |
| Thread Tools | |
| Display Modes | |
