Old 30th May 2016, 07:48 PM
Rosco Rosco is offline
Seats dropped in but still waiting for my seat belts
My Build Thread
Old 30th May 2016, 07:49 PM
Almost ready for the track!
My Build Thread
Old 31st May 2016, 09:22 PM
Little bit done tonight, the cable ties looked a bit naff on the brake lines so I tried swapping for some spiral wrap, I think it looks a bit neater
My Build Thread
Old 3rd June 2016, 08:46 PM
Well after waiting 3 months for my seat belts, they finally arrived today, so I turned up some top hats and spacers
I've had to lift them up a bit so Mr IVA mans happy, just need to sort some covers out next
I've gone for 4 points, see how I get on, would of preferred 6 point but I dint think until the chassis was painted
Also got the engine floor hatch fitted!
My Build Thread
Old 4th June 2016, 11:14 AM
garyt garyt is offline
I like the spiral wrap idea looks neat and saves any sharp edges on the cable tie ends.
Lovely build and your almost there, keep pushing
Old 4th June 2016, 09:36 PM
Well after 18 months of spending every hour I had spare in the garage or in bed not able to sleep thinking about the next bracket to make, the day finally came when she was to leave the garage for a test drive!
Me and my dad got it loaded on the trailer
Then off down my mates at Roger Clarke Motorsport, there on the end of an industrial estate,
Started off with a few steady runs up and down to see how she went, everything was perfect, just kept going up and down to get the brakes bedded in etc,
Kept pulling in and checking everything looked alright
Then set the brake bias up, just made sure it locked the fronts up first
The electric reverse worked sweet, but didn't last long as the motor pushed its self away, need to re mesh it then put a pin through I think
Also the big reverse gear on the prop was just rubbing on the aluminium side pannel, so need to swage that out a little
Next took it round the corner to my mates mot garage and he check the emissions, bit to high so just mapped it out with the power commander.
Next up, drop it on the rollers and check the speedo was working ok as it was a bit glitchy driving up and down
My Build Thread
Old 4th June 2016, 09:37 PM
The speedo was dropping out at 50mph, so luckily I had already made a wider pickup, swapped it over and perfect! Ran it up to 100mph and all sweet, well happy with that as it would of been a fail come IVA time,
Next was program the gear position on the digi dash, just a case of driving through the gears and telling it which gears which, but it's so much easier to figure the gears out with the number on the dash
All in all a brilliant first run out, I couldn't of wished for better really, just got the sort the reverse out really and she will be ready for the IVA test in two weeks time
My Build Thread
Old 14th June 2016, 08:31 PM
Well got the reverse motor re adjusted, then put a top hat washer in the hole above resting on the bracket, should stop it pushing its self away again
Also made some washer things to sort the sharp edges out on my seatbelt bolts
Painted and fitted
My Build Thread
Old 14th June 2016, 08:33 PM
Bit of a stack but should keep the IVA man happy
Also got some nut covers on my wheel nuts as the stud was poking through the nut
And that's about it, all ready for Friday morning I hope
My Build Thread
Old 14th June 2016, 09:20 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Looking great best of luck for friday
