#41
The deep ecu needs the earlier loom as the pins are thicker and less of them. I would sooner use the newer ecu so I can have the obd2 function.
Nowt again. |
#42
And I know have an engine to play with
Nowt again. |
#43
Good luck! I'm sure you will crack it.
#44
So ive striped the engine down to a tall block.
![]() And ive picked up a spare sump and flywheel from a 1.8 blacktop and started choping the sump. ![]() ![]()
Nowt again. |
#45
nice! Chop chop chop!
#46
Some progress.
Saturday. Having read off a local builder building a jig to chop the sump. An email was fired of and a quick ride across town see the top of the sump snipped of perfectly square. He then gave me the idea of building the short end up and running it back under the jig to make it square and equal to the rest. so another ride back an hour later, Thanks Martin. The bottom was mabe out of the last of the steel from the locost floor. ![]() Sunday. Having been dragged around Primark this morning I escaped to the garage after tea. I chopped up two pick up pipes and mocked it up with a fuel clip. When I got it where I wanted it I thought I would just get the tig out and join it up. Then I decided I would cut of the bracket and weld it on for suport. ![]() Being nagged to come in, I thought I would just tack the bottom on, I got carried away and welded it around. There is still one pin hole in the mig welding but the tig weld is good to go. Then I can test its oil tight. ![]() ![]() Progress may get a little slower as ive taken on another wiring job that was offered a few weeks back, vag 20vt on a dta into a vw Caddy
Nowt again. Last edited by big_wasa : 5th March 2013 at 10:17 AM. Reason: dead link |
#47
Finished.. So I thought I should finish of the thread.
Some progress.... Work has steadied up but that just means the wife had me do the garden So I've Cut up and remade the loom. Cleaned up the engine. Cut and shut the sump. Replaced the leaking cam cover gasket and grommets. ££ I've made up the alternator kit I've cut a set of plates out of 6mm plate for the engine mounts. I've now got to mount it to something. More progress, I seem to be doing loads but it doesn't look like much. I've cut a dust guard out of 1.5mm steel. Fitted the flywheel and a new clutch. ![]() So I made up an exhaust manifold from the st item. ![]() The engine fist start. http://www.youtube.com/watch?feature...&v=Mvo3lazzSVo And it still running an hour latter. http://www.youtube.com/watch?v=HIZO2...layer_embedded And now I bored as its sold ![]()
Nowt again. Last edited by big_wasa : 25th August 2013 at 05:20 PM. |
#48
Well done wasa, I knew you would get it going.
A nice and tidy little setup you got there |
#49
Thanks.
I've loved playing with it. Next project is "Ron's" off road buggy book to teach my lad a few things.
Nowt again. |
#50
That engine thingy sounds like it came from the depths of hell
| Thread Tools | |
| Display Modes | |
