Old 10th January 2016, 10:38 PM
SteveH1 SteveH1 is offline
so i had a few of these
Untitled by stephen harborne, on Flickr
Old 11th January 2016, 07:42 PM
garyt garyt is offline
good to see you making progress and yes it looks right, the diff flange sits way over to the o/s as yours is, and yes I sometimes need some refreshment similar to yours ..lol
Old 11th January 2016, 09:31 PM
So ive read in other threads about problrms with lower diff mounts on the mx5 diff
so do you think this would be up to the job
Old 11th January 2016, 09:40 PM
it really is the whole mounting setup , the arms and the nose. they all need to be hard mounted , so yes what you have there will work for the nose and then you need to sort the arm mounts.....
Old 11th January 2016, 09:41 PM
Yea i intend to get inserts made to hard mount it at some point but that money is better spent at this stage
Old 11th January 2016, 10:58 PM
Mines all poly bush mounted. But what you have done looks solid enough !
Old 24th January 2016, 09:15 PM
Had a bit of a blonde moment on saturday so i decided it probably best to stay away from the car
Got these finished up today
does this position work for the hand brake or does it interfere with anything
Old 24th January 2016, 09:18 PM
Rosco Rosco is offline
Haha pmsl how did you manage that?
My Build Thread
Old 24th January 2016, 09:19 PM
Isn't it meant to be behind the tunnel cross tube (further to the rear)?
Also get it as low as you can. I would like mine to be about 10mm lower (Sierra, book spec)
Ps it's been a long time since I looked at the book.
Old 24th January 2016, 09:36 PM
Yea it looks like it is in the saturn plans but it seems quiet far back rom what i can see plus you have to cut the cable then so does this cause problrms for the iva
