Old 12th October 2011, 06:46 PM
sven8t4 sven8t4 is offline
Back on track
Cost So Far = £376.62
I LISTEN TO THE VOICES IN MY TOOLBOX
Old 4th March 2012, 02:57 PM
Hey all Looooooooong time no see!!
After a few 'problems' at work my build got moved to my garage and sat there for 6 months.
Now I'm back into it full of enthuisasm once more.
Old 5th March 2012, 06:01 PM
Welcome back. Glad to see you are motivated again
Old 6th March 2012, 01:31 PM
Yeah back into it in a big way. With some help from Skov I've knocked up a set of engine monunts that I'll test fit tonight and tack weld in place. I'm using 4mm plate on the flat surfaces and 6mm for the 'legs' although may swap the plate for thicker but havent decided yet so any thoughts on this would be helpful.
Old 6th March 2012, 07:11 PM
Well quick session with the weld and out pops a set of trial fit engine mounts
Old 6th March 2012, 07:13 PM
not sure about the alignment though and may have some clearence issues to work round....
Any suggestions on a measurement to the crank pulley bolt from either side of the chassis?
Old 6th March 2012, 09:53 PM
I ended up with elongated oval holes in my engine mounts to get the alignment right
Old 21st March 2012, 11:14 AM
Think i may well end up doing the same.....
Started on the wishbone mounts yesterday with some threaded bar to get the alignment right.... my least favorite bit so far, really worry about getting them in the wrong place and the car is going to forever scrub tyres and crab. Granted I'd have to get it pretty far out to do that but still....
Also has anyone got a measurement from the center of the MX5 crank bolt to the chassis for reference on the alignment?
Old 21st March 2012, 05:21 PM
You should check out john's (skov) build thread and gallery. I think you'll be needing to take TR5 out. and lower it at least 40mm if it's a 1.6.
Old 21st March 2012, 05:23 PM
Hey, yeah I'm in frequent contact with Skov picking his brain but thanks
