Old 6th November 2009, 12:27 PM
Land Locked's Avatar
spot on , well done that man
right.... do you want another boring question or should i get back to work?
Thank you, though 'twas merely an edumocated guess.
Yes throw us another. I don't wanna go outside n fix my mates car.(hate rattles in suspension)
Old 6th November 2009, 12:35 PM
next question.......
how many actual cuts are needed to make the main frame of the chassis as per the parts in question 1 ?
now i,m getting really sad
Old 6th November 2009, 12:41 PM
You really need to get out more Andy
Will the total include cock-ups
Old 6th November 2009, 12:46 PM
Beyond sad.
107 ? uhm no notches add a few, 111?
Old 6th November 2009, 01:17 PM
i,m thinking each tube has 2 ends so that gives 2 cuts but then also all the other cuts such as the compound angles etc, so if it helps its over 200 cuts
the 3rd question is even more sad
Old 6th November 2009, 01:26 PM
400 + cuts in my case
I square cut all of my tubes first ( To get the steel out from under my feet )
The angles were cut as & when I needed them
Yep, there's a right way a wrong way & Ronnies way !!??
Old 6th November 2009, 01:47 PM
Tatey's Avatar
Tatey Tatey is offline
Bonzo i cut all of my rails like that as it meant i had a flat edge to then mark the next piece up from. Im guessing 243 for the amount of cuts...Now what really would be sad Andy, is asking us how many mm of steel we had to cut through and the amout of steel removed by making them cuts...
Old 6th November 2009, 02:07 PM
doh went out to lunch and missed it all. andy i thought you was busy
Old 6th November 2009, 07:51 PM
sorry guys, i was busy but was posting when had chance of a cuppa
the answer is between 202 to 250, maybe that narrows it down a bit for you
Old 7th November 2009, 08:37 AM
3GE Components's Avatar
I can only count to 20 & 1/2 when I am naked
Is that on a hot or a cold day Ronnie?
I knew the answer too, but then i should. If your talking chassis plates though Keith's your man, he knows them all off by heart.
Kind regards
John
