Old 21st August 2009, 10:22 PM
onedayTM onedayTM is offline
Default Ali body panels
hi all,
can anyone tell me whether the Ali panel at the rear comes up and over onto the top of chassis plates CP3/4, the upper rear suspension mounts. If so is this plate fully covered or is just up to the roll bar mounting plate.
Do you then seal around the edges with sealant?
tony.
Old 21st August 2009, 10:29 PM
the way i intend to do mine is just up to the level of the top rail, without going over .
thats how i have taken the info in the book, also the measurements of the back panel seem to indicate this, (tho haven,t got the book in front of me )
Old 22nd August 2009, 08:07 AM
dogwood's Avatar
dogwood dogwood is offline
This is how I did mine.
Yes I did seal all the edges, I used a black sikaflex.
HTH David
Old 22nd August 2009, 02:01 PM
David....
i like that hmmm....
is it 1 piece from the base rails up & over the top of CP3/4 ?
Old 22nd August 2009, 03:03 PM
David,have you fitted an extra mount to the diff rear bracket ?
Old 22nd August 2009, 06:56 PM
dogwood's Avatar
David....
Hi Mate,
Yea, one piece.
I cut it over long and bent it over inplace
then bolted the roll bar over it.
Yea I have fitted the extra bracket at the rear like the donor Sierra.
I don't know if it needed it, just belt and braces I suppose.
