hi all,
can anyone tell me whether the Ali panel at the rear comes up and over onto the top of chassis plates CP3/4, the upper rear suspension mounts. If so is this plate fully covered or is just up to the roll bar mounting plate. Do you then seal around the edges with sealant? cheers tony. |
the way i intend to do mine is just up to the level of the top rail, without going over .
thats how i have taken the info in the book, also the measurements of the back panel seem to indicate this, (tho haven,t got the book in front of me ) cheers andy ![]() |
This is how I did mine.
Yes I did seal all the edges, I used a black sikaflex. ![]() ![]() HTH David |
David....
i like that hmmm....is it 1 piece from the base rails up & over the top of CP3/4 ? cheers andy ![]() |
David,have you fitted an extra mount to the diff rear bracket ?
Yea, one piece. I cut it over long and bent it over inplace then bolted the roll bar over it. Quote:
I don't know if it needed it, just belt and braces I suppose. David |
