Old 7th August 2015, 06:13 PM
norton norton is offline
Thanks for the heads up stot, I'll drop them a line and see what they can do.
Does anyone know if the mx5 can be removed with the engine in situ? In the Haynes chassis not the original.
Old 8th August 2015, 07:57 AM
Not sure on the question, If you mean can the engine be removed with the gearbox in situ, yes with a bit of wiggling.
Old 8th August 2015, 08:14 AM
Predictive text fail!
I meant the sump, can that be removed without needing to pull the entire engine?
Oh, yeah I did that too. Easy as pie.
Old 8th August 2015, 08:24 AM
Ah great stuff, thank you!
Old 10th August 2015, 07:28 PM
Zinc/nickel plating success!
And does anyone know the bolt size to fit here?
Old 10th August 2015, 08:22 PM
I can't remember exactly as it'd been 3 years since I brought mine it's either an M12x1.25 or 1.5, but instead of shelling out for another two random bolts I ran a 12mm drill through them to take a standard common or garden M12 bolt.
Old 10th August 2015, 10:29 PM
Thanks for the tip. Much easier, I'll do that!
Old 16th August 2015, 09:08 PM
Default Brake balance?
Pedal box is in.
Are people fitting these?
I assume it affects brake balance?
Old 16th August 2015, 09:36 PM
Ianr Ianr is offline
Haven't test it yet but I have fitted it to my car - kept the MX5 servo as well. Its driving standard sierra front discs and the big (9"?) drums at the rear which I've fitted with Ka wheel cylinders with 17.3 ish pistons to make sure I don't get rear wheel lock up.
No idea if its right until I try it
