Old 26th October 2015, 09:15 PM
SteveH1 SteveH1 is offline
Painted my vice
and built a bench
ive always wanted a steel bench
Vice on bench
Old 26th October 2015, 09:25 PM
Then i got working on on the transmission tunnel
Most of the tunnel tacked in place
Old 26th October 2015, 09:29 PM
And the view from the drivers seat
made me a bit giddy
Old 1st November 2015, 09:27 PM
Got a bit done on the rear suspension this weekend
Also got my first chassis plate cut
And my beautiful distraction
Old 7th November 2015, 09:52 PM
So i was given this roll bar its a standard caterham 7 bar
So my plan is to cut off the original mountings on the thick bar and put a flat bar plate on each end.
Then make a plate the same as cp3 and cp4 and mount them 50mm higher straight above cp3 and cp4 with nuts welded on the inside
Like build a box if this makes sense 50mm high
can anyone see a problem with this
Can i then weld 50mm box section between these boxes with the seat belt anchorage's welded into this bar
Old 15th November 2015, 09:23 PM
Ok so im not sure what to do about the roll bar
so i started making some of the chassis plates and despite what people were saying about just buying them laser cut i actually found the fabrication of these plates very rewarding and satisfying maybe its because there is a bit more work involved or maybe its because i saved money who knows.
so i got these drill bits a while ago its amazing the difference a good drill bit makes
i also got these during this week
m18x2.5 bar
Old 15th November 2015, 09:38 PM
So not sure what to do About the roll bar so when making cp3 and cp4 i cut the roll bar end plates and drilled them on top of each other so they are an exact match
both plates drilled
both plates nuts welded
Old 15th November 2015, 09:45 PM
Old 16th November 2015, 04:46 PM
If you have the means to do it,cut a hole in the roll bar plates and put roll bar through it and weld it,it will pull like a bast*rd when you do weld it
Old 16th November 2015, 09:10 PM
like the main bar will pull towards the centre
and surley welding it to a flat plate would be better than a plate with a big hole
not really sure what you mean
