Old 18th January 2016, 09:24 AM
RichardH RichardH is offline
Default gearbox sensor wiring
can anyone tell me the wiring colours to the neutral and reverse sensors on the mx5 gearbox, the sensors have green wires but the other four wires from the loom to these connectors have corroded and fallen out the plugs so i don't know how to reconnect them, i have the haynes manual but that part of the loom isnt shown in the diagram.
Old 18th January 2016, 02:47 PM
Baz1 Baz1 is offline
Thumbs up Gearbox switch wire colours.
Hi Richard,
My donor vehicle is a 1996 1.8 mx5 5 speed. The switch mounted on the drivers side of the gearbox has brown/white and black wires and the switch mounted on the passenger side has black/yellow and red/green wires. Hope this info helps.
Old 18th January 2016, 04:58 PM
thanks for that i will go check later.
Old 18th January 2016, 06:54 PM
garyt garyt is offline
on my 1.8 2003 5 spd
reverse switch is black/yellow and red/yellow
neutral switch is violet and black
this is the same on a 2001 1.8 5 spd wiring diagram
good luck
