Old 1st February 2016, 09:10 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Default Bloody compressor
So the other day my compressor packed up so narrowing the fault to the pressure switch I ordered a new one
this morning the new switch arrived so I went to the man cave and set about changing it so removed the old one and started removing the gauge and the outlet
I made the grave error of leaving the pressure unloader with It's lovely split ring till last
Anyway if you find yourself in this situation dont do what i did and slip with the spanner you could end up like this
anyway 3 hours in a and e and a day wasted not to mention the screaming at the wife like my arm falling off
Old 1st February 2016, 09:16 PM
SteveH1 SteveH1 is offline
Should of jus pulled it out duck taped it up and carried on
Old 1st February 2016, 09:42 PM
You could go into industrial body piercing.
Old 2nd February 2016, 08:18 AM
14 hours in hospital one day with gallbladder problems in December 2014 and did not take it out until April 2015.
You were lucky
Old 2nd February 2016, 10:12 AM
Ouch, its only a scratch get on with it you wuss
Old 2nd February 2016, 10:14 AM
Your starting to sound like an English rugby player
Old 2nd February 2016, 10:33 AM
vmax1974's Avatar
You lot are all heart thanks lads
Old 2nd February 2016, 01:05 PM
rpjg1975 rpjg1975 is offline
And I bet it was tight enough and you thought I'll give it one last tweak!!
Old 2nd February 2016, 02:09 PM
All heart? hell NO
Old 2nd February 2016, 10:46 PM
At least you wont put it down and lose it
