So
I have properly started now, the story so far, which is discussed in other threads,
That’s the current stage of my build, will try to update regularly but there may be times where I don’t do much for a while. Also will not write so much next time as I know I prefer pictures to text so here they are. ![]() ![]() ![]()
God loves a trier Actual cost so far = Have chosen to stop counting incase I incriminate myself - Cost ive told the wife = A hell of a lot less than I have spent. -
and more:
looking good, the way your chassis sits now its worth getting some block of wood across each of the chassis rails and screwing down to the table , it will stop any twisting when welding, obviously at this point you are only tacking but it will still distort, i clamped as much as i could until the whole chassis was together and its straight as a die , ive read some horors of twisting as much as 10mm out
I always think it's strange how small it looks from the bottom rails then as you progress it takes shape really quickly!! Don't forget to go side to side and front to back when welding to eliminate heat build up
Russ |
I assume this is when fully welding and not just tacking? If so that's what I was planning to do so was going to research the best way when it's all tacked
Do you still have your hard top from the MX5 if so how much would you want for it I may know someone looking for one
Arfon |
Unfortunately I don't, the guy I bought the donor off took that and a few other panels, It cost £150 so can't complain.
That's a pity
Arfon |
im over six foot as well, two things to watch for mount the seat so it can go as far back as possible and have the seat in before welding the steering column in, i built to the book and couldnt get my knees under the wheel. i fitted the scuttle and seat them moved the column about till it was comfy height wise
