Old 26th February 2017, 06:16 PM
Wain Wain is offline
I have pretty much ripped the wiring appart and checked all earths to rule that out, changed the bulbs and now thinking lens as well.
Yes they are 7", if they will fit i will give them a try. Shall i pm you my address?
One day it will be on the road......
Old 26th February 2017, 07:16 PM
garyt garyt is offline
Yes pm me your address I have one spare unit that you are welcome to at least if that sorts the issue then your halfway there, will get it posted tommorow all being well
Old 26th February 2017, 08:39 PM
Message received will get it posted tommorow oh and I have ignored the other part of the message
Old 26th February 2017, 09:21 PM
Thank you, appreciated. I will let you know what difference it makes to the pattern once it is fitted.
Old 27th February 2017, 05:09 PM
posted this afternoon , hope it helps
Old 28th February 2017, 01:33 PM
Cropper Cropper is offline
I failed the IVA on the same thing, MX5 build with 5 3/4" headlights, all brand new. I was advised by the tester to get better bulbs, as they had seen this issue before, so i stumped up for the best bulbs i could & it passed OK second time. Just a note that the kick up they fail you on isn't tested on an normal mot!
Old 28th February 2017, 02:29 PM
Got the retest next Tuesday so im hoping changing the lens and new bulbs will do the trick.
