Old 5th October 2020, 03:59 PM
old_bill old_bill is offline
Lightbulb Headlights staying on.
Wired up headlights but they won’t go off. They all work perfectly ie side, dip, beam and flash. Side lights come on from stalk and the mains come on from ignition. There is a black and brown connected to pin 56 on both stalks and lights operate when this is earthed. Any help appreciated.
Bill
Bill
http://www.flickr.com/photos/old_bill/
Old 5th October 2020, 08:39 PM
Tatey's Avatar
Tatey Tatey is offline
Bill, it sounds like there is either a faulty switch or a short circuit on the main headlight circuit.
If you disconnect 56A do they still come on with the ignition? If do come on even with it disconnected it sounds like a faulty relay.
If they don't come on with it disconnected it sounds like a faulty headlight switch.
Old 6th October 2020, 05:08 PM
Hi Tatey
Did as you suggested. Lights stay on when disconnected.
Checked relays and stalks (have spares and replaced). Still have continuous circuit. I can’t fathom how the lights are operated from the right hand stalk. I connected pin 30 to +ve and when in second position pin 56 lights the test lamp. I thought this pin was the earth. I think I’ve just done something stupid, but for the life of me can’t figure out what.
Bill
Bill
Old 6th October 2020, 09:18 PM
These sierra stalk/wiring? if so what year so i can dig out the diagram
Old 6th October 2020, 10:37 PM
Hi Twinturbo
They are sierra stalks from 1992 sapphire 1.8cvh. I’ve spent days trying to figure out what’s wrong. I have two fused wires from the battery to pin 30 on the relays. Two wires from the ignition to pins 86 on relays. Pins 87 on the relays activate headlights. Pin 56b ( brown & white ) to 85 on dip relay and 56a to 85 on
High beam relay. Brown and black from pin 56 on right hand stalk to 56 on left hand stalk, this is earthed.
The dipped lights come on when ignition switched on (pos 2) even though position 2 on light stalk not activated. The lights work fine when left hand switch is put on high beam or flash. POS 1 on light stalk activates side lights. Bloody things won’t go off until ignition off or disconnect 56 from earth.
I have changed relays and stalks but still the same problem.
Bill
Old 7th October 2020, 09:18 AM
Tatey's Avatar
Bill, if you have grounded pin 56 that is connected to both switches this sounds like it is your issue.
Both switches should have ground on pin 15 and pin 31 not on 56. Pin 56 just needs to be connected between the two switches.
Grounding pin 56 is by passing two of the switches.
Old 7th October 2020, 02:05 PM
Thumbs up
Thanks Tatey you were dead right. Just had to earth to pin 31 and headlights now working fine.
Feel a bit like that guy in the Simpsons DOHh
Many thanks you’ve made me a happy man
Bill
Old 7th October 2020, 05:39 PM
Tatey's Avatar
I'm pleased I could be of help and that it was a simple fix!
