Old 16th August 2009, 01:09 AM
Default Left hand drive chassis
There were plans of LHD chassis here before the forum hack.
I'm nearing the stage where I have to make, or at least plan, the tranny tunnel. As far as I remember, the LHD chassis wasn't a simple mirror image of the book one, right? Also, I remember someone complaining that on the suggested LHD chassis the clutch cable attachment on the Type 9 bellhousing is fouling the tranny tunnel.
What should be the centre offsets of the U7 and U8 tubes? My plan is to put the driver side upright so that the MT-75 pedal box would fit, and leave the passenger side upright at 214 mm from centre axis, so that it sits square with BR9 rail. Makes sence? But what is the width of the MT-75 pedal box?
Old 16th August 2009, 07:09 AM
Matthew Matthew is offline
The MT75 pedal box is 36mm narrower than the standard one, making it 214mm from side to side across the base (the 250mm dimension at the bottom of Fig 4.37 in my copy of the book).
The MT75 dimensions aren't symmetrical so you may have to adjust U7 and U8 to make this work left hand drive.
If you want more detail I've a printed out copy of the modifications that were posted before and could scan it in. You'll just have to excuse the oil stains
Matt
Old 16th August 2009, 08:40 AM
squbti's Avatar
squbti squbti is offline
hi guys, i have the left hand drive plans on my pc ,let me know if you want me to post them.
samy
Old 16th August 2009, 11:43 AM
Samy, I'd be very grateful. Matthew, I would be interested in more detail, but perhaps it should be in a separate topic for MT-75.
Old 16th August 2009, 12:02 PM
squbti's Avatar
Old 16th August 2009, 12:04 PM
squbti's Avatar
Old 16th August 2009, 12:07 PM
squbti's Avatar
hi alga, hope this helps . i have 2 more drawings but i have to try to cange the size on them & i´ll post them as soon as i can.
Old 19th August 2009, 02:06 PM
DaveW DaveW is offline
Thanks squbti do you have te rest off it
Old 19th August 2009, 06:18 PM
squbti's Avatar
hi dave , i have 2 more drawings but i cant upload them because the size is too big & i´m so useless with the cumputer & cant seem to find a way to change the size but they´re not realy so imprtant , they just show the overall view just like in the book but handed. i´ll try to fix them & upload them again later if i can but i think you have all you need anyway.
Samy
Old 20th August 2009, 01:09 AM
Thanks very much!
