Old 16th September 2009, 09:50 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
Originally Posted by RAYLEE29 View Post
Hi,
I believe there is more than one way of causing bumpsteer but i may be wrong, ive been modding cars for nearly 30 years and have experience of people fitting wheels with too much offset.
if you move the contact patch too far away from the middle of the point where the kingpin inclination hits the floor you will adversly effect the handling
when you go over a bump the car will try to steer into the bump if thats not bumpsteer what is it??
anyone remember the carlos fandango ad with the anglia with oversize wheels!!
Ray
Using too small an offset will increase the scrub radius, not necessarily a bad thing until you get a blowout. It will increase the 'feel' of the steering, the self centring. It wont affect the bumpsteer, that is where the different geometry of the track control arm to wishbones will cause a steering input as the hub assembly rises and falls.
Old 17th September 2009, 03:44 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
as i said before you need to consider the centre of the contact patch to where the theoretical kingpin inclination line hits the floor and this will i assure you create a badly steering car if its too far out from what is intended
Ray
Old 17th September 2009, 04:09 PM
Chris Gibbs's Avatar
Chris Gibbs Chris Gibbs is offline
http://www.youtube.com/watch?v=nqqZ28m8uCo
Old 17th September 2009, 08:22 PM
RAYLEE29's Avatar
BRILLIANT Chris , I wish id found it first
Ray
Old 23rd September 2009, 08:07 PM
Rik178m Rik178m is offline
Will 20mm really effect it that bad? Could put them back on ebay without a problem but I like the alloys.
Do we have a final verdict? sell or use?
Old 23rd September 2009, 09:16 PM
Matthew Matthew is offline
If it was me then I'd keep them until I had a chance to drive the car with them on and see what it felt like. You can always sell them later if they don't work out.
Matt
