Old 16th October 2009, 07:10 PM
thwang thwang is offline
hi
good job andy but if you dont want to tackle the front lower wishbone plates i think i have a spare set gathering over spray and dust.
regards thwang
im only over the boarder
Old 16th October 2009, 08:25 PM
cool is it a lazer cut one i didnt fancy making the lower wishbone plates to be honest they look far too intricate to by hand
Andy
Originally Posted by thwang View Post
hi
regards thwang
Old 16th October 2009, 09:03 PM
andy is so tight he cant squeek. its not like he cant afford it, the real problem is that he thinks it might wear his trousers thin from the friction of making the squeek.
only kidding
Andy braggs that he managed to get his lights cheep, but he fails to mention that he got so carried away at the rally design stand he had to call home for a budget increase
Old 16th October 2009, 09:17 PM
what i didn,t tell you Ash was that i had to do the washing up for a week for the budget increase
if i,d not phoned home to "ask permission to spend more" i,d have been sleeping with my dogs outside in their kennels for a week
mind you.... wouldn,t be the first time i,ve slept with a dog or two
what Ash didn,t tell was that we then teamed up to try & get a bigger discount off the fancy dash he intended buying, it worked to a point
Old 17th October 2009, 01:26 PM
hi andy
laser cut ones
Old 22nd October 2009, 12:46 PM
NEroadster NEroadster is offline
I did manage to make the lower wisbone plates by hand the biggest problem being bending them. The fabrication just required a lot of patience and more time than money. Bending them was acheived in the end by heating the plate and bending in a vice. I have to admit to being seriously pleased with the end result. I made my wishbone brackets not totally happy with them but they are on the car and everything fits and moves as it should do
Old 22nd October 2009, 07:51 PM
hi andy
been sat on the shelf so need a clean.
thwang
Old 26th November 2009, 04:27 PM
Ricky Ricky is offline
Default front suspension brackets and jigs
Hi. I was wondering if someone could help me in fig 4.25 it shows you must put a spacer when using the jig to attach the front brackets now does those spaces go on the front part only or on top and bottom and the inner brackets to
Old 26th November 2009, 04:31 PM
i mean does it only go on top or does it go on the bottom and inner brackets to ?
