Old 10th March 2010, 09:50 PM
Default Awesome Bargain & Failure
Well I thought I got myself a right bargain. Some guy rallying a Pug got some wheels (4x108 ET35 magnesium OZ Racing off a Sierra Cosworth) but they were the wrong offset for a pug. So I got them for a steal. I blasted them at work and had them powder coated, then threw some Toyo Proxies on
I was feeling all smug. 4 powder coated wheels and new tyres for a tickle over £300, weigh less than 6kgs each as well. Well until I went to fit them They are Group 4 Rally wheels so the standard sierra studs are too short. So now I'll either have to change all the studs over or get some special adapter nuts.
Don't really know where to go with this lot now.
Old 10th March 2010, 10:00 PM
I'll give you a tenner for the lot, just to help you out!
Get the studs, they're nice wheels, and Rally Design do them cheap.
Adrian
Old 10th March 2010, 10:23 PM
studs are easy... Burton do em.
Old 11th March 2010, 01:36 AM
change the studs. as tt says its easy to change them. they can check your studs are the correct length for the wheels at iva so "special nuts" may not be the best solution.
i had to fit longer studs on my car when i fitted my team dynamics wheels
Old 11th March 2010, 07:50 AM
Enoch Enoch is offline
No problem at all to change the studs, I had to do that on the last car I built. I got mine from Speedshack in Uxbridge. Only cost a few quid, they do them in lots of different sizes. They are just pressed in to the hubs.
Old 11th March 2010, 08:35 AM
Awesome. I'd asked this question on Locost Builders and no one knows a thing.... to be honest, most of the guys there seem to talk crap about everything BUT kitcar construction I had the same, complete lack of advice, when I asked about DOHC clutch information I'll give speedshack a call this morning and see what they can do. Thanks guys
Old 11th March 2010, 09:14 AM
https://www.burtonpower.com/product_...7&sTxt=s tuds
GRAYSTONE.
Old 12th March 2010, 09:50 PM
OK got the Graystone studs.... seems straightforard.... hold on... is this going ok..... NO ITS NOT Wheels take 8.3mm valves, not standard 11.5mm push in car valves. That is totally brilliant. I'm well happy this Can't inflate the wheels.
Old 13th March 2010, 02:00 PM
richardk richardk is offline
Did you mean this thread ?http://www.locostbuilders.co.uk/view...php?tid=131684 that you got the correct answer in the first reply
Haven't had time to do much research as I'm off out now but are these any good? http://cgi.ebay.co.uk/Brass-pump-adapter-valve-converter-presta-to-schrader_W0QQitemZ170345385525QQcmdZViewItemQQptZU K_Sports_Leisure_Cycling_BikePumps_SR?hash=item27a 9604e35#ht_500wt_956
Rich
Gallery updated 01/11/2010
http://www.kilmartin.it/cgi-bin/gallery
Old 14th March 2010, 10:17 AM
aerosam's Avatar
aerosam aerosam is offline
This is one of the main reasons I emmigrated over here. Here you find a small group of focused memebers who really know what they are on about. You may have to wait a day for a reply, but you don't have to trawl through 3 pages of BS and pisstakes to find an answer.
LCB has just got way too big, it's one step away from becoming another barryboys.com.
Gg
