Old 7th April 2010, 11:35 PM
jasongray5's Avatar
I belive most people glue 'em! Sikaflex i think its called...
Jas
Old 8th April 2010, 12:40 AM
geeman's Avatar
geeman geeman is offline
Jas
Hmm... Wouldn't have thought about glueing it on, but sounds quicker and easier thn making up brakets. Ok, I'll get a suitable gle and get them on asap.
my build pics
Old 8th April 2010, 09:51 AM
Enoch Enoch is offline
Nice lookinjg job, keep up the good work.
Old 8th April 2010, 10:01 AM
Jas
Never come apart if ya get it wrong mind, or if you have a bump you will be replacing the whole rear end.
Old 8th April 2010, 10:33 AM
geeman's Avatar
what version of sikaflex should i be using as there seem to be hundreds?? it seems like it'll either be 221 or 252?
my build pics
Old 8th April 2010, 10:54 AM
Got some of this to do my floorpans
http://cgi.ebay.co.uk/SIKAFLEX-221-E...item2557e2988e
Old 8th April 2010, 11:14 AM
geeman's Avatar
ok, will buy 2 tubes of it. thanks
my build pics
Old 8th April 2010, 11:19 AM
jasongray5's Avatar
Apparently if you do need to get it apart, then you just need to slide a razor blade between the 2 surfaces, a right bitch to do so im informed tho...?
Old 8th April 2010, 12:43 PM
geeman's Avatar
Default Clutch problem...
ok, ive got the clutch cable in, however, i am not able to push the pedal in, the clutch arm seems to be stuck,its not hitting the chassis, theres enough room for it, it has about 3 cm of play in in, then it doesn't move at all, i dont want to apply excessive force and break it... the clutch hasnt been used for about 6 months, what could be the reasons for it not moving, the only thing i could think of is i nay have hit the lever on something while the engine/box wasn't in.. any suggestions??
my build pics
Old 8th April 2010, 01:01 PM
Is the leaver free from obstructions?
Sounds like the release bearing may be stuck on the input shaft.
