Old 9th May 2010, 07:10 PM
carlknight1982's Avatar
Im in for a set please mate + Covers
Old 9th May 2010, 07:33 PM
My back of the envelope calculation puts the weight of the kit at around 3200 g, which means postage would be around £20 if split into two Airmail small packets. I guess that leaves me out
I think the rear upright lower bolt will be shorter. Upright - 120 mm. 2 bushes: 100 mm. 2 washers - 3 mm. Nylock nut - 12 mm. 2 more spins of the thread - 3.5 mm. Total: 238.5 mm. Seeing as this is the bolt that interferes with 14" steel wheels for some people, I'd keep it at minimum.
I would also suggest adding front upright strut pinch bolts, M12x45, to the kit.
Added to the list mate
I have put a copy of the list in the first post of this thread
Old 9th May 2010, 07:47 PM
That shipping is a real killer
Like you say, the only reliable way of getting them out to you would be by Airmail & yes, split into two packages to avoid the 2kg weight limit
Thank's for the info Albert .... I will go through the lengths thouroughly before I order up, want to get it spot on.
Would you think the upright pinch bolts would need to be stronger that 8.8's ?
Your thoughts would be most welcome .
Old 9th May 2010, 08:08 PM
I'm a complete numpty at mechanical engineering and don't have a clue about how to calculate the tensile load on that bolt, but I can just about make out an 8.8 rating on the original Sierra bolts.
Old 9th May 2010, 08:20 PM
Cheers Albert
I guess at 8.8 the thread would yield before the bolts yeild point & there won't be any real torsional load on the bolts as such.
If 8.8's were good enough for Ford, they'll be good enough for me
Old 9th May 2010, 08:21 PM
David_17's Avatar
David_17 David_17 is offline
Could i be added to the list thankyouplease
Old 9th May 2010, 08:31 PM
All sorted & on the list
Two sets left to go & that will take care of a full box of the longest bolts
Old 9th May 2010, 08:50 PM
geeman's Avatar
geeman geeman is offline
would be interested, but i dont need the diff bolts if possible. Thanks
my build pics
Old 9th May 2010, 08:59 PM
Luke2842's Avatar
Luke2842 Luke2842 is offline
I'll be in for a set as well please Bonzo + nut covers
Luke
