Old 15th June 2010, 01:10 PM
mark mark is offline
I used rivnuts just incase i wanted to remove it, just as well coz i took it off about 3 times before iva messing about with things!
Dont forget if you are using fibeglass panels they will add a little thickness on the sides too. You dont want to attach the scuttle flush with the chassis rails before fitting the sides as you will end up with a small step where they meet
