Old 22nd August 2010, 03:57 PM
kwr kwr is offline
Default what type of engines can you fit
whats the biggest engine you can it in the kit
does a rover v8 fit
Old 23rd August 2010, 06:33 AM
snapper snapper is offline
The V8 Rover will fit therefore the Range Rover 4.6 will go in.
A small block 8 may well go in but why would you
Old 23rd August 2010, 07:30 AM
Aerosam has an BMW V8.
Old 23rd August 2010, 08:08 AM
aerosam's Avatar
aerosam aerosam is offline
That i do!
It's, ahem, only a 3 litre, but it has DOHC heads so it's very wide. Rover V8 will fit no trouble at all.
Old 28th August 2010, 03:41 PM
Eternal Eternal is offline
Nice! If doing a straight six you will most probably need to stretch the chassis a tad. But pretty much anything with 4cl in a straight line will fit apart from flat 4's.
Skyline Roadster
Old 28th August 2010, 04:16 PM
A flat 4 does not have 4in a line.
Old 28th August 2010, 04:34 PM
james3004's Avatar
I did wonder if a subaru boxer engine would fit but i think it would be far too wide
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 28th August 2010, 04:45 PM
Ops yeah you are right mybad
It might be able to fit but would take a bit of reworking to keep the chassis stron and would stick out the sides a bit and get in the way of the engine bay diagonals. Also would need to make sure it would not foul with the wheels ect. But it would be nice and low thats for sure.
Skyline Roadster
