Old 17th October 2010, 10:23 PM
rpjg1975 rpjg1975 is offline
Default 2mm thick steel cutting?
Hi guys,
Am I right in thinking I need to use a thin grinder disc to cut this or could I use a jigsaw?
Thought i'd ask before I make an almighty balls up!!
Russ
Old 17th October 2010, 10:42 PM
Tatey's Avatar
Tatey Tatey is offline
I used 1mm thick slitting discs (very thin grinding discs) they slice through 3mm thick steel like a knife through butter. I have used 5 discs to cut out all of my chassis plates and do a lot of other jobs.
May i ask what you are using the 2mm steel for?
Old 17th October 2010, 10:44 PM
yeah, course. i've been given it to use for my floor panels
Old 17th October 2010, 10:50 PM
that's going to be heavy!
Old 17th October 2010, 11:20 PM
Will it be too heavy or can i get away with it? It's cost me nothing and i thought they aren't massive bits so wouldn't make too much difference?
Old 17th October 2010, 11:24 PM
It,ll be fine for your floor, admittedly its heavier than an ali floor but if you don,t cover in the prop area that,ll save a bit of weight
It was free....use it
ps... don,t do full welds all in one go, stagger the welding, to avoid heat distortion.
extra info....Spuds Roadster has a steel floor, doesn,t slow that car down.
Old 17th October 2010, 11:48 PM
Cool, all systems go again. Cheers
Old 18th October 2010, 06:33 AM
I'm told that welding on a steel floor can lead to corrosion problems, and I believe it's actually not allowed in locost racing because of this. I understand the corrosion is caused by there being 2 pieces of metal close to each other that you can't get at to apply rust preventative, and that the thin gap causes moisture to be drawn into it.
Old 18th October 2010, 10:57 PM
Jigsaw cuts it fine and cleaner and easier to control .
Dont quote me as I have not verified it but I am fairly sure the MSA blue book requires a steel floor for racing.
Old 19th October 2010, 06:13 AM
You could well be right, but I have a feeling, I'm sure I read it somewhere, that such floor had to be rivetted on rather than welded. Obviously the rivetting would then allow sealer to be applied to the joint, thus preventing the rust problem
