Old 3rd February 2011, 07:57 PM
the one on the right is a stock MK2 none adjustable lower half.
Front left looks like a MK2 adjustable lower half
Rear left looks like a MK2 top and bottom.
What column do you have.
Old 3rd February 2011, 08:02 PM
fabbyglass
This part of a seven nearly always looks crap as the shroud doesn't meet up with the dash, a single tube with a steering wheel on the end of it with switches elsewhere looks far better
Old 3rd February 2011, 08:03 PM
Bit of a mystery there Jas
Wish I was close enough to pop in & have a gander
I have no idea how many different types of column & shroud were used on the sierra !!
I'll keep an eye in the breakers mate, you never know, I might come across another complete Sierra steering assembly
Old 3rd February 2011, 08:11 PM
jasongray5's Avatar
Ask at the chemist for XL.
Quality!!
My donor came with the non adjustable shroud, so im guessing non adjustable?
Old 3rd February 2011, 08:14 PM
jasongray5's Avatar
Yeah it wouldnt be so bad if one of the other covers fitted it, but they dont, so hey ho. I do have the column out of the p100, but there is no key to get the barrel out of the ignition, and I really need the steering lock for IVA.
Fabby, didnt someone make their own shroud using a plastic sweet jar? Im sure it was Dogwood said he had?
Old 3rd February 2011, 10:09 PM
Seen that Carl, hoping to do something like that for the Mx-5 Dashbaord to incorporate it into a combined scuttle / dashboard giving the scuttle a built in areoscreen while using the Mx5 dash built into the scuttle / dash. Giving a shape similar to the MNR car. If you see what i mean......
GKD Legend did the same with a BMW cluster, works very well IMO:
http://www.gkdsportscars.com/slideshow/p028_0_3.jpg
Last edited by alga : 3rd February 2011 at 10:10 PM. Reason: added a quote for clarity
Old 3rd February 2011, 10:25 PM
Jas
I changed a Sierra lock the other day without the key
Twated the little detent pin in with a pin punch. Prised the lock out of the housing slowly, slowly .... Once it was part way out, I was able to turn the lock assembly to the no 1 position & pull the rest out with ease
New lock just popped straight in as it should , jobs a good un
