Old 7th September 2011, 06:21 PM
Default suspension bracket alignment!
hey all! its got to the point in my build where i have nearly welded everything on! ....but the suspension brackets!!
does anyone have a jig made up i can borrow?
as to be honest I'm plopping my pants on this section!
it would be great if local'ish i could pick it up
Any help would be greatly appreciated!!
Michael
Old 7th September 2011, 07:25 PM
You can borrow mine if you want. Bit of a distance though! I got a picture of my set up on my blog.
http://leroysroadster.wordpress.com/...23/march-2011/
Old 7th September 2011, 07:32 PM
That looks very like the setup i had before i used the wood for something else.
Old 7th September 2011, 09:42 PM
Michael
dont worry i was as well at the same point
its not as bad as you think a simple two bits of board and 12mm studding and a load of nuts and its not as bad as you think
just skip the book jigs and simplify thats what i did. i set the gaps on the brackets on 500mm long bits of studding with plain nuts then cut simple pair of identical boards with holes to pass the studding in with nus and washers at the right height and distence apart, trim out bits to clear the tubes
make sure your on centerline for all your mesurments and with a few cuppers and messureing twice and a few tacks and your there
just dont rush and take yor time.
*top tip* if your build board is set flat and level a nut and thin sewing cotton maks a good plumb line (black or red is best)
Old 8th September 2011, 12:06 PM
Thank you i do appreciate it! although like you say distance is..well far haha!
I shall probably do something similar , like Baz-r has mentioned
suppose i had better find some chunky straight wood
Cheers chaps!
Old 8th September 2011, 04:43 PM
right chaps thanks for your help/ideas and inspiration!!
I'm going back to basics on this as i have a meter of spare box im going mark the holes and drill them then bolt in my m12 studding so its all nice and accurate at least then i can clamp the box to the frame.
shall pop a few pics on later
cheers!
Old 22nd September 2011, 05:45 PM
andysredmini andysredmini is offline
Have a look at the suspension jig post on my build blog.
There are plans I have drawn for a simplified jig that does both sets of brackets in one.
http://bamaroadster.blogspot.com/
Regards
Andy
