#21
![]() [quote=Bonzo;68393]
There are plenty of 7's that handle, I have built a few but had no interest, time or space to build a Roadster. Sooner make something different....as for being a Troll well that made me laugh........ ![]() |
#22
![]() can't wait to get mine built and on the track to have a look at this understeer problem.
From my understanding it will be the high g corners where theres a lot of body roll. Aparantly there isn't enough camber gain on the front suspension, i.e the camber angle can't keep up with the body roll angle. Thus causing the outside front wheel to camber out under heavy cornering. Thus causing a bit of understeer. The front shock angle is also quite low so effectively you loose stiffness the more wheel travel (or roll) angle you see. Three things I'll be playing with to solve this (or minimise this) 1. Static camber angles, probably come up with a track and road setting. 2. Limit the body roll with some antiroll bars (or stiffer strings) 3. Weight distribution etc to give a more neutral oversteer charactersitic. Other than Ash I'm not sure who else has actually experienced the understeer and this could just be down to the basic geo setup. As said on the road it isn't going to be a big problem, on track you might feel like you not quite getting the most from the tyres. No biggy. In my opinion a wider chassis would look naff
Build Cost so far £xxx (Given up adding it up) - She Starts!! Build Thread Here: http://www.haynes.co.uk/forums/showthread.php?t=5501 |
#23
![]() From experience of the Roadster I put together in conjunction with Saturn the total opposite is true and has a lot of oversteer when corner weighted and set up to suit the driver,it is wearing R1R Toyo,s at about 26 psi or there abouts and standard Protech,s and shorter springs.
#24
![]() Quote:
![]() AndyH
#25
![]() Quote:
#26
![]() Quote:
Gallery 2 http://www.facebook.com/album.php?ai...4&l=a9831a9319 Gallery 3 http://www.facebook.com/album.php?ai...4&l=3f0d42c523 Gallery 4 http://www.facebook.com/album.php?ai...4&l=efb083b7df Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5 cd3a Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=1&l =fe779b358c |
#27
![]() I personally find with my car it would be hard to quantify the setup as it currently is
I did use some inital numbers from locost builders but after driving it i altered things here and there to make it behave how i wanted Spud has obviously played with these cars more than me so maybe he has some exact settings to start with, but with so many variables such as engine weight, power output, springs/dampers, wheel and tyre choices make everyones car different and behave differently Im sure you will soon get it feeling "right" once you get it on the road and have a play |
#28
![]() Quote:
Front: Toe in 2deg, camber 3deg (will vary on driving style), castor so that it just starts to self centre Rear: Toe in - none, camber 1/2 deg Corner weighting the car is important with the driver in the car, adjust the springs to get the car even all round then you can balance the car between the front and rear. Adjust the ride height, 100mm front / 125mm rear, to as low as you dare for speed bumps and turn up the bump / rebound to as stiff as our crappy roads will allow. If you go on a track day you can drop the car right down and damper setting as stiff as they go and it will make quite a difference. Hope that helps.....AndyH
#29
![]() Spud you are a star (and my wife says you're a darling
![]() Thanks for the setup info - duly recorded and noted! ![]()
#30
![]() Quote:
![]() Have a good weekend......AndyH
