Old 13th May 2013, 09:32 PM
DaveyB DaveyB is offline
Default Pinto engine and gearbox weight
Hi, could anyone tell me the approximate weight for a pinto engine and box.
DaveyB
Old 14th May 2013, 07:20 AM
jps jps is offline
DaveyB
I'd guess at 100kg perhaps? They are hard to lift!
Old 14th May 2013, 07:32 AM
From Westfield World.
Engine (cc): - 1996cc
Basic Power: - 105 bhp
Weight: - 135kgs
Height: - 69cms
Length: - 56cms
Block: - Cast Iron
Head: - Cast Iron
Valves: - 8 Valves, Single Cam
2nd Hand: - £100 (approx)
Ease of fit: - Easy to fit but this is a tall engine
Ease to tune: - Easy as they are well established and also easy to work on for the DIY'er
Upgrades: - 150bhp= Kent FR32 cam, gas flowed head, twin 45's. 160bhp= as before plus Kent FR33 cam
Availability: - Relatively easy to find as plenty of Sierra's still about. Approx £950.00 to rebuild
Gearbox fit: - Standard Type 9 from Donor car
Overall: - Very cheap option with plenty of parts available, very robust engine. Exhausts on right which limits swapping engine at later date. Slightly on the heavy side.
Type 9 is 31-33kg
Old 14th May 2013, 09:11 AM
Try lifting a 24V V6!
Old 14th May 2013, 08:25 PM
Thanks for the replys great information will be really helpful,a guy over the road has an engine I think is suitable that he does not want, I thought we could man handle it but will use some form of lifting aid now.
Thanks again
DaveyB
Old 15th May 2013, 06:33 AM
tip it over to slide a sheet of ply under it and drag it across if its only over the road. You would be amazed the weight a couple of guys can drag on a piece of ply.
Old 15th May 2013, 11:29 AM
jps jps is offline
A wheelbarrow works too. That's how I have shifted mine - engine and gearbox together although it's easier if you split them. Not difficult to get them apart. Might not do wonders for the wheelbarrow though...
Old 15th May 2013, 04:35 PM
SteveMX5 SteveMX5 is offline
Great engines, got one in the Westfield on twin DCOE's just about bomb proof except for the odd oilway problem. They are affectionately known as boat anchors for a reason tho
Old 16th May 2013, 07:25 PM
Scaffy pipe and rope......
Old 16th May 2013, 07:29 PM
I have a number of wheeled dollies for my engines to sit on. Very usefull. Just have to watch they don't tip off!
